Clio mk1 1.4Rt 1993 starts but immediately cuts out
Car  1.4 rt Clio 1993
Hi there, I’m currently investigating the issue with my 1993 Mk1 Clio 1.4 single point injection. The car will start on the button but will cut out straight away. Could it be to do with the crank sensor if the pump isn’t getting power once initial start? Or could it be a faulty injector or something to do with the Cts ? Any suggestion would be greatly appreciated?
Tom
I have spark and it does start for a second, Could this still mean immobiliser as I thought this would have stopped all ignition .
Does it have a MAP sensor?
Only ask as it's a fairly common thing on the 16v/Williams to have a similar issue if the MAP sensor is faulty, unplugged or has a leak in the vacuum hose for it
Just had another look and I’m no closer. Does anyone have anymore suggestions on what to components to test or common issues with these.
