06plate 1.2 campus sport struggling to start
  clio campus sport
Hi all, got a 1.2 06 plate clio, had it for a year now just had its first mot and service since ive owned it. however last couple of weeks its been a total nightmare to start up, really hit and miss tho, most of the time it starts up no bother but other times its a real pain; takes 2 or 3 attempts and its really struggling and when it does turn over its revving its nuts off. At first i thought this may have been as it had barely any petrol in (bein a student bum) or just cause it had been sat there all night/day or parked on a bank etc. filled up, still being a little biatch.
Also this problem has only seemed to occour since I got it serviced but that was about a month ago and as i said its very hit and miss...could this be anything to do with it?
any advice appreciated, could have come at a worse time as im in middle of exams and skint too.
thanks a lot
  Clio 172 Ph2
TDC sensor on the side of the engine going into the gearbox.....
First thing i'd check
Sven ;)
  clio campus sport
Hi, cheers for that, im a totally noob so what is a tdc sensor and what does it do? ill have a proper google of it tommorrow.
how much does said tdc cos to replace and how much should I expect to be charge by a garage?
cheers james
  monaco 172
It's about 20 quid from Renault. A garage will probz charge about an hours labour although its.a 10 minute job. If you've got a 10mm (think its 10mm) socket then you can easily do it in minutes.
However, on my old Clio 2 taking off the sensor and giving it a clean sorted out my problems.
  clio campus sport
Massively late reply on this one guys but thanks for all your help!
Turns out it was the temperature sensor fuse on its way out-hence why the problem was so intermittent.
Looks like I have another ignition problem at the minute tho, perhaps something to do with the key fob chip/imobiliser
