on Friday on the way home (after 100 or so miles of driving) the engine management light appeared and the revs dropped (without me taking my foot off accelerator) engine management light went out and revs went back to normal. It carried on doing this all the way home (especially if i dropped below 4000 revs) at one point the revs died all together giving me no drive so i had to pull over and switched off) i started up again and it run fine but carried on losing revs before 4000. On saturday took it to the garage came up with some faults on the computer :
Air Temp Sensor
Crank Sensor
Pedal Accelerator
and a few more, though because it was running fine at this point the garage wasnt totally sure what it could of been so, they told me to drive it for a bit until it came back on, which it didnt....did about 50miles all through the day absoloutly fine. Sunday morning fine but then started doing it again on way back down the motorway and again cut out. Then it started again, travelled most of the way back then it started to do it after 4000 revs aswell, made it back and left it over night. Came to start my car this evening drove about 800 metres and sam happened again losing revs and causing itself to stall/cut out. so much so cant really drive it anywhere ...Any Ideas??
Air Temp Sensor
Crank Sensor
Pedal Accelerator
