1.4 2004 Clio overheating issues.
  Renault Clio 04 1.4L
I am sadly having a problem with my otherwise good Clio. I had noticed in the last month or so my car's radiator fan running for a few minutes after the engine was switched off, but I put that down to summer weather (wishful thinking in Britain...). However now my coolant temperature indicator is maxed and I am seeing a warning light appear. So far my solution has been running the fans on full heat and pointing them out the window which seems to work but obviously isn't a permemant fix.
What could the cause be and is there anyway to fix it without going to garage?
Mavez
  Clio & No Megane
thermostat is probably knackered, unless there is no coolant in your expansion bottle
