So I'm thinking of replacing my engine in my current car, it's a mrk 2 clio 1.2.
I want to put a 1.6 16v in there, I will be declaring it on insurance and such, it's more for me and my dad to have as a side project anyway. Just a bit of fun to do and cheaper than buying a 172.
I have a small list of things that will need doing, but also need advice on other bits.
The list of parts:
1.6 engine
1.6 gearbox
1.6 engine loom
1.6 ecu
Questions:
1. Will I need to slice the new loom into my existing one or could I just plug the entire loom in?
2. Is the gear ratio the only difference between the 1.4 and 1.6 gearbox? As the 1.4 engine is only 10 hp less I believe.
3. Would it be better to get a new ecu or should I get an aftermarket one? As I doubt I'd be able to get the ecu from the donor car.
4. The imobiliser, with a different ecu in the car will it be triggered? If so is there a way to bypass this as the car will be stored in a garage most of the time anyway, and it's only a fun project so really be used on the road.
5. The brake system, the 1.6 has a different rear setup too the 1.2, obviously making sure the car will still stop is a big thing and will be done properly, although I can't find if there are any differences between the rest of the system, need some help here please.
If there is anything else I'm missing please inform me, I'm aware of insurance, but it won't be a massive problem as it will be declared.
Thank you.
The list of parts:
1.6 engine
1.6 gearbox
1.6 engine loom
1.6 ecu
Questions:
Thank you.
