10mm hubcentric spacers?
  Golf mk4 R32 Audi A1
Morning... does anyone no where I can buy 10mm hubcentric spacers ?
I can find 15mm 25mm kits but under that all I can find is the 5mm shim style spacers which is a no no..
Ideally want a kit with bolts..
MLB
Don't think 10mm is available as a hubcentric one, believe I've read it's because it's not big enough to fit the lip?
As far as I know PMS do a 10mm but that's a slip on..
Brigsy
  T.Turbo
As above all 10mm are slip on, which is usually fine as you still have a small amount of centre bore for wheel to locate.
Stub axle spacer much better option on rear though
