172 HT Leads (Buying advice)
DaveDreads
Which HT leads should I buy for my 172?
One of it's problems is an electrical fault causing it to cut out and arching HT leads are the most likely culprit, the fact that I can't remember them ever being changed or if they have I can't remember when, means they're due for a change anyway, they seem to come in 8mm 8.5mm 10mm and range from £20 - £100, I have no clue which ones I need or where I should buy them.
I did a search on here but that just left me with more questions, any advice?
npt
  BMW 320d- 172 cup
I would just get standard new leads, think you can get them from renault parts direct
YorkshireKyle
Not all gingers stink of piss. But I do.
So what size do I need and where do i buy them from?
I couldn't find them on RPD.
R3k1355
Are you sure you're ready to screw this car up after last weeks efforts on the Golf?
hopgop1
I just went for some cheap-ish NGK leads. No issues so far on my 182, I figured if they can make good plugs they can make good leads, didn't feel the need to spend £100+ quid on wires for a road car.
DaveDreads
How much were they and where did you get them from?
DaveDreads
Ok nice one, looks like a full set for a 172 is basically a hundred quid whichever I buy, at least I have a couple of options, cheers lads.
DaveDreads
£25 is fne i'll get them off ebay, I don't trust autodoc after reading a lot of people get sent they're own brand stuff rather than what they actually ordered.
hopgop1
Yeah those ones linked above are what I got, full set. Fit fine and work fine, no complaints. Have seen people mention slightly different lengths between 182 and 172 leads, but I think you can just route them slightly differently and that may only affect 182s.
