172 ph2 not cranking
Persiflage
Car  Clio 172 Phase 2
Attempting to sort a random throttle position ch A issue I’m have sourced a reasonable cost used throttle body.
Having fitted it and with a fully charged battery I am now faced with a non cranking engine.
Battery charged, immobiliser light acting as normal, starter is clicking but not turnIng, headlamps are NOT dimming significantly when attempting a start.
I have not yet refitted the air filter and pipe work but can’t see this as a factor.
The car has been sat for a couple of weeks but I have never had any starting issues in twenty plus years.
Has anyone any thoughts.
I had a similar issue. Try a new battery, battery can show as fully charged but may be a dud. If new battery starts car use multimeter to test voltage off the battery. If 13.7-14.7v alternator is ok. If measuring around 12.6v then alternator is faulty.
I did wonder about the battery but I’ve tried it with a booster attached and a supplementary earth via jump lead… same result
