197 75° Thermostat in a Clio 172/182
I don't see the point of a lower temperature thermostat in the cooling system.
It's designed to get up to temperature and then stay within the recommended operating window. Fitting a low temp thermostat just means it opens earlier and the coolant gets cooled earlier, which means it takes longer to get up to operating temperature. Once it's running, I highly doubt a 'normal' thermostat would be closing again, unless you happen to live in Siberia in winter, lol, so a low temp stat would make no difference apart from increasing warm up time and the opportunity for engine wear??
Just depends really. Oil takes longer to get to temp so that's where the majority of your wear comes from anyway.
Suppose once you change one variable then the other changes too
hmmmm, I might have a 75°c thermostat in mine. When I check the temps with a ODB dongle the temp rarely goes above 77-80.
The previous owner must have changed it for a low temp one as I have not changed it since I got it.
I guess I might want to change it out for a normal one? Car is only used on weekend drives and the occasional Nurburgring trip...
I hope it didn't damage the car.
perhaps it's stuck open?
i've just got a euros special in mine. Opens at the correct temp (on my 197)
