been changing the oil/filter,i got the filter off easy with oil filter plier..(removed fuel guard).
I fitted the new filter hand tight..then got rubber gloves to turn it more..
will this be tight enough?(didn't want to use the pliers to tighten it )
also drained oil,put new washer on..i know you have to tighten it to 20nm,but my wrench only starts at 40..
as I don't want to strip the tread,i have tightened it with a wrench...
I cant check for leaks cause it started to pour down.didnt want to put the oil in.
