3 Clutch cables in 8 months
Car  Valver
First one snapped, got a replacement one, non-genuine, was stiffer and also snapped, then fitted a genuine renault one about 6 months ago if that, now it just snapped again the other day??? No signs, I just pushed the pedal down and *snap* gone!
Any ideas?
Yeah the clutch has started slipping now as well, just not looking forward to having to shell out for a new one :(
Cheers!
Signs of clutch on way out is snapping cables. So by replacing cable you are not sorting the problem. Clutch and cable replacement should sort it.
Just a temp fix until I can get the clutch changed! Took 2 of us about 1-2 hours to change the cable, real b**terd!
it could also be that your pedal ratchet is shagged, and if u have the wrong cable i.e to short it will snap them easy, go to renault or gsf, get a new pedal and cable, that match, fit them and see if it does it again, a shagged ratchet will also make the clutch slip !
