3 Faults on a 1.2
  1.5 Clio Dynamique
4 Faults on a 1.2
ok heres goes
Fault No1. intermittent starting issues. car is being used every day and seems to happen every other day. takes 4 longish turns of the key to get it started and when it does it screeches like a b**ch until you rev it over 3k rpm
Fault No2. Interrmittent horn failure spent a while sqealing while wet but now just give up whenever it wants to.
Fault No3. Rasping noise coming from engine imbetween 2.5k and 3k. runs as normal before or after these values
Fault No4. Little spots covering the interior mirror like the mirror has a rash
any ideas to any of them??
Number 1 is your TDC sensor ontop of the flywheel. Common problem. If its not been replaced before you will need the sensor and loom. Just pop into a Renault garage, they have it on file anyway
  Ph1 track 172
screeching on startup would be your powersteering/altenator belt slipping,
just replace them for about £15.
no4, its an old car, bits will need replacing,
pop to a scrappy and get another one lol.
Number 4:
