2009 Clio 1.2 throttle body fault/clip/relearn
Hi all,
My brothers 2009 1.2 16v Clio had been sat for 18 months. Started up as if it was running the day before. Drove it up home and check injection appeared. Clip is showing it as a throttle body fault. It’s intermittent so it sometimes isn’t present when the engine is started.
Live data on clip is showing some discrepancies on throttle body position. It won’t go to 100% throttle with the pedal on the floor. Mid 70% is the maximum it will read. So I think it needs to relearn.
What’s the best procedure for this? Can it be done on clip?
Thanks,
Rick
