3rd brake light.
  Clio 182 cup
Recently found out my 3rd brake light has stopped working it's says it's a sensor but wouldn't the sensor do all 3 brake light not have a separate one for the spoiler one ? Is this common or is there a easy way over it ?
Cheers in advance Dan
jenic
Connectors are a bit dodgy on the cup spoilers i found, try taking the light unit out and giving the connector a wiggle and clean up :)
jenic
The whole light unit prises out, use a wall paper scraper, thats what i used :)
A screwdriver will just damage the spoiler
Gaz_
  Extreme mode
Yep, mine actually failed, i was going to fix it as mine had water ingress wich had damaged some resistors etc, but iirc they are about £20 for a new unit, so i just bought a new one!
