75mm bore
Car  Ph1 172
Looking at buying a set of wheels, they are 35 offset with 4x100 pcd, so should fit perfectly. However the bore is 75mm. Does anyone know where and if I can get required spacer/spigot rings for it. I want this to be safe I assume spacing it to 60.1 would be????
Anything else I need to know???
Cheers – tom b
What wheels are they? You'll be fine with spigots, think my old superturismos were about 75mm with the spigots out.
the other way to do it is to use wheel studs and nuts, instead of bolts.
will be tracking the car eventually, i want it to be secure and safe, so id rather not have a gap for the bolts to take up
