A problem with reverse lights
Car  Clio sport 02
Hi!! Im from mexico and i have a problem with reverse ligths of my clio sport 2002 i need change the reverse bulb but i dont know where is it in my motor, please help me !!!
Open the boot. Behind each brake light cluster should be a plastic screw sticking through. Undo it, and you should be able to pull the whole cluster away from the car. There are about 5 clips around the back of the cluster, slightly bend each clip back to release it, and once all are done you should be able to pull the back panel off. All the bulbs are on this panel.
Sorry i was wrong i wanna say the reverse switch i dont found it and i need change it, the reverse switch where is it?? Help please !!!!
