ABS Sensor rings ?? (reluctor rings)
  Renault Clio Sport 172
Hi , I have a Clio 172 , 2003 model and the ABS ring is cracked on the N/S/F I know that they can be replaced and Reluctorring have an option for 26 teeth , 44 teeth or a 182 ring , now mine has 44 teeth so is this correct for the 172 ?? I don't know if I'm being over cautious or if there is a difference in the ring . Can anyone help ?
Thanks in Advance
Paul.
Sourced a ring at www.cliospares.co.uk £12.50 plus postage . The fella was helpful and really knew his stuff about Clio's , I'd say "give them a try" if you need parts . will fit it next weekend .
  Megane R26
Are you sure the ABS ring can be replaced?
As when i had my mk 2 ph2 1.6 i had one that cracked and just hung on the d/shaft flailing about and to fix the prob i had to get a new d/shaft. I was told the rings werent replacable.
they are but most renault dealers dont know
