actual bhp
I think when the engines are dynod out of the car, they get 166bhp.
Theres a Rolling Road day in Bury this coming weekend with loads of 172s going. Will have some at the wheel figures then...
Tom
  EV (s)
its between 150bhp - 172bhp
it depends on how it was made/run in/rrd
Quote: Originally posted by griff_90 on 19 November 2003
Please dont start this thread....
Why ever not? Not every thread has to turn into a slanging match. The fact is that the F4R engine puts out around 166bhp. Doesnt bother me, its still fast enough and most people assume it has 172bhp!
Lee
  BMW M2C
Ive had between 158 - 168bhp. As Tom says, it varies a lot depending on the RR and conditions.
  172 Cup
When its 3 pages long and still hasnt answered the original question Ill remind you..
  172 Cup
Quote: Originally posted by rickyboy on 19 November 2003
Sorry griff, (again)
Just 150-172 is quite a big difference
Its not a problem mate its just that there is no definate answer.
lol, fair enough
The difference is because some 172s seem to come out of the factory down on power. I had a MK2 172 before my MK1 and it had 16bhp less at the wheels than another mk2 172 RRd the same day. Whats more, mine didnt get the lowest output that day :eek:
I dont think anyone has ever adequately explained why some are down on power. Two explanations that Ive heard are 1) some problem with the VVT and 2) squashed/bent/damaged air intake tubes.
Tom
  EV (s)
its down to build tolerances.
if you ever visit a car factory and do end of line testing (as i have) you will see the diffrences between cars.
Rich-D
  E90 LCI 330d
i know its meant to be cup 172 but has anyone actually had one on a RR and got any figures?
AS has already been said, there will be a few of us going on the rollers this Saturday, so we should have a load of actual figures soon.
Its not 172bhp as we know it though, its 172ps or bhp/DIN which equates to ~169bhp in what we in the UK call "bhp" and should be about 143bhp @ wheels.
However, there seems to be quite a bit of variance between cars and quite a few have been known to make less, but others more, so unless you actually get your car on the rollers youll never know for sure!
Lee
  BMW M2C
And even then you still wont know for sure. Mine had a 10bhp variation from one RR to another!!
Rich-D
  E90 LCI 330d
Was that power @ fly or power @ wheels you got?!
I dont trust the "guesstimate" power @ wheels figures you get on the rollers...
Lee
  BMW M2C
I had the figures for both Rich, but only have access to the one set here. The Northampton Rolling Road showed 159.6bhp @ FW and 132.1 @ wheels.
Power Engineerings road showed 168bhp @ FW.
  Nissan R35 GT-R
Here we go again!
The Clio 172 and Cup BOTH make 172 bhp. This power figure is read using the DIN measurement standard. The DIN standard is almost identical to the SAE specification, but I believe the ambient temperature must be slightly lower to comply with the DIN specification (68 F), which leads to a mild power increase.
Everything else is the same. Engines must have all accessories installed and run the full production exhaust.
The Clio makes 172 bhp. If it were measured in SAE by Renault then it would make 169.64bhp, but Renault chose the use DIN, so 172 bhp is what it makes.
The new Porsche 911 (996) GT3 makes 381 bhp, and they have clearly used the DIN spec as it is a German standard, so you could argue it makes less if you were to convert to SAE, but they too chose DIN (as do so many other manufacturers).
The fact of the matter is that there is no standard BHP - you cant say, "DIN, whats that in BHP?"
Its like saying you owe me 10. 10 what? We know were talking about money, but 10 pounds is more than 10 US dollars!
Renault figures, and the ClioSport site for that matter, state 172bhp not ps so that is the figure I quote when playing Top Trumps ;)
Darren
  Nissan R35 GT-R
Darren
Good man.
Rich-D
  E90 LCI 330d
Would like to see what your @ wheels figure was from PE.
As for the Northampton one, the give you a 17% loss which is a little high, but not as OTT as some Ive seen which are way out.
Keeping that loss as a constant, means you would have 139bhp @ wheels from PE.
I reckon a spot on example should be ~ 143bhp @ wheels in an ideal world.
Rich-D
  E90 LCI 330d
Which is what I said earlier...
  Elise/VX220/R26
Just to add my two penneth. I think that all 172s have near enough 172 BHP. (Due to miniscule manufacturing tolerances etc) Its far more likely that there are loads of dodgy rolling roads that are ill maintained and not callibrated properly. Rolling rodes when you think about it are quite a crude way of determining output from and engine which is many many moving parts removed from it (ie a big margin for error throughout the process)
  Elise/VX220/R26
PS if the 172 was going out of the factory with 165 BHP that would have major implications with the way they advertise the car (like Mazdas recall in the us for a wrongly advertised power output)
Rich-D
  E90 LCI 330d
So what if several 172s & Cups are all tested on the same rolling road on the same day and they all varied, some by quite a bit?!
Becuase this has happened in the past... at RE in fact...
Its just that the people on this forum that have experience of dynoing engines (as in more accurate than a Rolling Road for measuring flywheel output) have said that the F4R puts out 166bhp. I wouldnt have a clue as I havent had my engine dynod. Doesnt really matter at the end of the day, its only as fast as it is!
  Elise/VX220/R26
Purely the added up effects off all the variables of using a rolling road to test engine output. I rekon if you rrd a car in the morning and then came back in the afternoon and did it again there would be a difference.
lol, carry on like that and no one will turn up on Saturday ;)
Rich-D
  E90 LCI 330d
Why dont we see on Saturday?!
I personally doubt it, although I accept that there could be a small variance...
  172 cup,s2 rs turbo
in all adverts/brochures renault claim 172bhp,if thats incorrect then its false advertising but trying to prove it hasnt got 172bhp would be different.renault wont accept any figures from a dyno run by some aftermarket tuner
Exactly, look at the 1/4 mile times for a slightly modded Cup/172 low 14s! I know for a fact my car has way more than 166 hp, FFS I was running side by side with a stripped out cammed up Nova 2.0 16 valve up the strip (the 2 fastest FWD cars there) Now if I really did have 166 hp there is NO WAY my cup would stay side by side with that thing! As someone said above believe a RR if you want but goto another one and I can almost guarantee you make more/less.....
  Elise/VX220/R26
Quote: Originally posted by jonnyboy on 19 November 2003Purely the added up effects off all the variables of using a rolling road to test engine output. I rekon if you rrd a car in the morning and then came back in the afternoon and did it again there would be a difference. [/QUOTE]lol, carry on like that and no one will turn up on Saturday ;)
lol yeah maybe I should shut up haha. I did look into loads or rolling roads and RE seemed to be the one most people had good things to say bout. Well lane are supposed to be spot on with their accuracy but they were such t**sers to deal with!
  2005 Audi A3 3.2 Quattro
Guys, just to drop in a little bit of my own here.... transmission losses.....
when stone cold they are high - due to the gearbox oil not being warmed up to normal operating temperature, but if you have run the car around for a while then transmission losses drop quite a bit - now how are any RR operator that dials in a transmission loss meant to know what state the gearbox oil is? - they cant so unless they use rundown as a good estimate system the flywheel figures are going to be crap.
Ok...looks like I was over tired last night when I tried to post
on an engine dyno a 172 engine will make 124kW which is probably the most standardised measure of power.
124kW = 166bhp (metric) = 169bhp (imperial) = 172bhp(DIN)
