No. But then again it depends on what part of the car you're claiming warranty on. If it something to do with the air flow/engine then they may say that your induction kit is the problem, just to get out of it. If its dodgy suspension (for example) then they will sort you out under warranty.
Most noise is probably K&N 57i kit (I have one it sounds mad! ), but this is an open filter that will also suck in hot air from the crampt renault engine bay:dapprove: . Lots of people on here would probably recommend the viper for more noise and improved performance. perhaps 1-2bhp increase Assume you mean 182?
greens filters are louder than k&n but for performance you really want a heat shielded one as engines tend to run better with cold air no point in even getting one if your just gona be filling it with boiling hot air from the engine!
