Adding DVD drive to my PC, Q?
  Turbo'd MX-5 MK4
dell's are very easy, the main case usually opens very easily and the drives just slide in and out, you'll need to make sure the jumper on the back of the drive is set to 'cs' (cable-select) and attach it to a spare inferace connection and power lead, once that's done the OS will just detect it and it will automatically be ready for use.
  DUB mk2 golf gti!
yer old on clips out should do!disconect the leads from the back!shouldnt be more than 2 in it!depends if u have another drive in there!?cause then u start getting in master and slave b****cks!just buy it!lol and if u get any trouble come on here lol!:cool:
  HyperAlloy Combat Chassis
Just a straight swap for the drive you have, I personally wouldn't bother having 2 drives in my system.
I wouldn't pay £62 for a Dell specific one, just get a standard recorder for £25-£30.
M
M7CUO_V6
Cheers guy!
I have a cd drive, and theres a blank space under it where the dvd drive must go.
I'll just have to give it a bash.:)
M
M7CUO_V6
You mean get rid of the cd and replace with dvd drive?
Where can i get one that would be compatible?
DrR
  VW Golf GTD
Do you just want a drive that reads DVD's or writes them to?
  Monaro VXR
Any dvd drive / writer will be compatible. You can also pick up dvd writers for under £20 from comp shops.
  Clio 5 1.2 16v
yeh m8 dell are steap, if you are looking for a good supplier ebuyer.com is a def just like fm-ava-969 says but in regards to fitting it you need to slide the old one out using the green sliders and the un screew the 4 screews and then put the new on in its play screew it back up and connect it just like the other was. Need any help give us a shout
Stuart
Well it personal choice really, personally I don't see any compelling reason to have 2 drives when 1 will do everything.
Just about any standard drive will work. Ebuyer/dabs etc, I also like SVP
http://svp.co.uk/products-list.php?cid=86&PHPSESSID=617b52319774cc841b78e0894a0f5755
I usually go for NEC or Pioneer stuff. Just make sure you get one in black to match the case ;)
M
M7CUO_V6
No not bothered about writing them, just want to get gaming:)
If i replace the cd for dvd drive can i still use it as i have been doing before, for importing and burning music(cd's)
  Not a Clio
To burn CD's you need a drive capable of burning, if you've been doing this then you have a CD Writer, not just a CD reader.
Replacing the drive with a DVD Reader would mean you would not be able to burn CD's.
If you replaced it with a DVD Writer then you could read and write both CD's and DVD's.
I picked up my DVD RW from PC World in the "brown box" section for about £35 last year.
