Adjustable Damp'ing, DIY?
Rob
So, I have a feeling my FK coilovers may be slightly uneven on the front with regards to the damping.
Is this something I can just change myself? I was thinking just wind them both to as soft as possible, then go say three full turns tighter on both, go out and test, then repeat?
Is there more to it than that or will I be alright?
  BG 182 FF
I am not 100% sure but to me that would be the best and most logical way of doing it if you feel it is uneven damping.
Read
Go to the second page gives a couple of tips about how to set suspension up
Hope that helps
  Astra 1.9Cdti SRi
Mine has always been diy, on my Spax adjustables they had something like 24clicks from soft to hard, so just adjusted the front say 15clicks on each side, easy never had a problem with them and always been spot on :) just then had to adjust the rears so they match the front,
