Adjusting xenon headlights?
  182
IM just wondering how i would be able to adjust my xenon headlight on the passanger side as it is shining pretty high up while the drivers one is fine, thought there was a switch of some sort to adjust the hight of the beam?
Any advice
cheers
Da
  Less
It's on the rear of the headlight, a white allen - key adjustor which will move the beam up and down on the desired headlight.
There isn't a dash adjustor, it's automatic on the 182.
Da
  Less
Allen key is standard, 6mm I think off the top of my head. Oh and do it with the engine running, otherwise the headlight will 'home' once you start the car for the first time.
