Hi all,
I am picking up a mk3 pre facelift '07 1.2 TCe this weekend, aware its not a sport model but I am looking at wheel, tyre and suspension components which i am guessing would be the same across the mk3 model? Are there any common performance parts sites usually used?
I will be using my Mk3 as the daily commute, hence the smaller 1.2 turbo engine rather than anything larger (other project car is aiming for 400bhp/ton), but still looking to improve the handling for the daily drive, the car currently has the stock 16" alloys running 195/50/16 tyres.
Tyres
Ideally I would want swap out the alloys to be running 195/50/15s for better tyre choices but that would give it a 4.2% smaller size, are there any other off the shelf tyre sizes commonly run as an upgrade to give a better choice of tyre options?
Suspension
Is there a usual upgrade route for the mk3 in terms of suspension? I am thinking probably best to go with an upgraded damper and spring setup rather than a coilover for road use, I am guessing that there are poly bush options for the car?
Interchangeable parts
The car already has the stock spoiler and side skirts so not looking to bolt on any cosmetic items onto the car, more interested in parts that can be swapped out between the sport models and the non sport models, anyone got a list?
Thanks in advance!
Tyres
Suspension
Thanks in advance!
