advice/opinions please
  Renaultsport Clio 197
I have a 1.6 16v and currently thinking about performance mods, basically what mods are best for improving performance to a noticable amount?
and in your opinions is it actually worth modifying the 1.6, 'cos I keep thinking I could be putting the money I spend towards getting a better car in the first place!!?? (but I won't be able to afford that for a long time yet!)
all help/opinions much appreciated.
TeZ
  Non RS : (
panel filter?(K&N), lowering springs (eibach pro, sportlines?), exhaust?
many options can be done im in the same situation just gonna do a bit to mine then save for a 172.
  Tweaked Leon Cupra R
Devil de-cat, cat back system, filter, coilovers.. easy way to blow 1-1.5k but you wont regret it!
coilovers alone take you to a level that you can make std 172's struggle to keep up!
  Ford Puma
Only thing with Coilovers is spend the cash. Variant 3 KW's have adjustable springs/dampners/height for maximum effectivness but will set you back a bag of sand!
Plenty of options for ECU Remaps or chips etc etc too just find a good company with proven results :)
there's loads you could do , exhaust system (decat) performance induction kits etc , i'd look at good brakes too , you'll go quicker longer knowing you can brake later .
remap and ecu work imo would be the last thing you want to do , once all the other mods have been set up correctly .
yeah, same brakes as the mk1 valver so lots of upgrades out there.. i have brembo max discs with ferodo ds2500 pads and ss braided hoses. work a treat!
re-map next me thinks!
