Hi guys
I have a Type R in black and it's in desperate need of polishing. The paint looks ok after a wash but is looking a bit dull and there are scratches and swirls everywhere.
I did start buying a few detailing items a while ago, including a DA. A month or so ago I polished the bonnet with Jeff's Acrylic Prime and I think I used a Chemical Guys Orange pad. Anyhow the finish came out ok, but there are so many chips on the bonnet that have now ended up bright white as they are full of polish. What's the solution to this? Is there a better polish I should use that won't do this?
I don't want to start doing the rest of the car until I sort it.
I was looking at Poorboys Black Hole which sounds good to fill swirls etc, but then I saw it's to be used after the polishing phase? I'm assuming that's not gonna fix my problem of all the white stone chips.
I don't mind buying a new polish and couple of other bits but don't want to end up spending a fortune.
I have collinite 915 was to use which I haven't even opened yet. I also have some AF Power Seal. Just need to get this polishing malarky done to make the paint look a bit better.
What would you guys suggest?
