advice please
  Titanium 182
after only 2 years im back in a RS this time a 182. other than the alternator being knackered and being fixed under warranty i have another cople of Q's
1. where should the temp gauge sit when up to temperature
2. what rpm is normal idle.
i think thats all i need to know (for now)
thanks
DaveDreads
1 : Slap bang in the middle
2 : 850rpm unless remapped then it can be a little higher, but normally under 1000.
It can be a little higher on start up untill up to temp.
  Titanium 182
hmmm thought as much ! my temp is running lower on the dial and the revs are idling at around 1000rpm what would cause this ? cts ,thermostat?
DaveDreads
Tbqh this is where my knowlege ends mate, :eek:
i'm sure one of our resident grease monkeys will be along at some point to clarify.
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
Could be the CTS, H02 or the station but I'd guess, without seeing the car, it's the CTS
  Clio RS 172 /Trafic
I wouldnt worry too much if the temp is a little bit lower as long it warms up. It's going to do more harm if it gets too hot. The gauge should get to the middle in normal conditions.
