Audi A3
Evening all.
Had an issue up on a track day at Anglesey over the weekend.
Air con pump had siezed, eventually jumping the belt off, leaving no power steering, battery light on etc... all the good stuff.
I couldn't get hold of a new pump. So was removed for the time. Took the belt to a parts seller nearby, found a shorter one and fitted it for good measure... saved the day. Did track time and made it back to the midlands.
My question is, is this a viable option to run long term?the belt used was shorter to avoid the gap where the air con pump was, fitted with enough tension and certainly seems to do the job. Im not great with cars, had some assistance from a friend and his dad and they all seemed happy. But I thought I would ask here to see if anyonr has seen anything similar.
