Air Con Hissing Sound
MorroN
Hi Guys,
Flicked on the A/C for the first time in a while yesterday and I noticed it was making a weird constant hissing sound, almost like letting down someones tyres.
Definitely only happens when the A/C is on and I think I can hear the engine revs changing when the compressor clicks in.
any ideas?
Rich-D
  E90 LCI 330d
When you get an aircon service, they will remove all the old refrigerant, hold the system under vacuum for a certain amount of time to check for leaks, then add the correct amount for the system.
They all lose a small amount per year, there's an acceptable leakage rate, so eventually they do need refilling, that's perfectly normal.
