Airbag fault code B1080
Car  Clio v6 255
Car went in for an MOT and I presumed the airbag + service light was the common loose wire problem. However the diagnostics returned the above code and "airbag control module fault" "see Renault" the garage never had a clip I am assuming it was a general Bosch or similar reader.
If anyone could shed any light on what this could be so I can try and get this sorted. Unfortunately the nearest Renault garage is 60miles away in Dundee so I only want to make the trip if necessary.
Cheers in advance!
