AIRBAG LIGHT ON HELP!!
i had some bucket seats fitted by paul172cup and he fitted a by pass circuit so that the airbag goes out and ultimately works however the light has come back on and i cant seem to c anything wrong with the wires he fitted..what does everone think the problem could be..could this be fixed from reanult quickly..or am i f**ked!!!
id say get paul172cup to have a look, if he donre the work then hell know what he played with
if you take it to renault you will pay through the teeth because you have messed about with the wiring for the airbax and seatbelt pretensioners
yes that is the pre tensioners, but there has been a bypass fitted so id recommend habing paul take a look
