Airbag service light...
  182 Cup
I followed the advice of the posts on here and cut away the old connector and fitted my own one on both driver and passenger sides. The light is STILL on though!
  Renault Clio 1.2 16v
Im trying to read the link for fixing the service light problem and im getting this message - can anyone help please?
heppelstone16, you do not have permission to access this page. This could be due to one of several reasons:
  Polo + Micra
i got a 2002 clio and sorted the passenger side and the lights went off for a while now come back on
could the drivers side be at fault???
Seat belt warning light
The SERV and AIRBAG lights come on its a common problem (almost every has it) its due to the wiring of the pretensioners going to an open circuit. Fiddle with the wires under the seat an the problem will go away.
On the early cars the solution is to look under each of the seats. You will see a grey connector.
On the passenger side disconnect it and cut the Blue and Brown wires off both sides. Then solder the Blue wire to blue, and the Brown to the other brown. Make sure you use insulating sleeves over the soldered connections..
Under the driver seat there are two pairs of wires in the grey connector.. Only cut the Blue and Brown wires and solder them together as above.. Reconnect the connector..
On the facelift cars it is ONLY the passenger side connector that is affected.. So again cut and solder the Blue and brown wires.
