alarm help
riz
  Jaguar XFR
i used to have the 2 beeps if i locked car 2 early and i know thats a knwon fault now that is gone away and i just get a little beep sounds kinda quiet and like a fadign battery sound any help???
Another common problem is when you lock the car the alarm beeps 2 or 3 times.
Reason: The alarm system has received a signal from the vehicle ECU that the ignition is 'on' causing the alarm to beep. This signal is only received by the alarm for 3 to 4 seconds, after this time has elapsed the alarm stops beeping.
Solution: It can only be resolved at a Renault dealer. Ask the dealer to contact the 'Renault alarm help line' and quote reference
'RS+15'.
