Alloys: WIll these fit??
  Ph2 172 (black bean)
Will these fit a ph2 172?
Tyre Width:205Aspect Ratio:50Offset:20Number of Studs:4Stud Diameter:108Rim Structure:One PieceRim Diameter:16 inches
Also
All 4 wheels are fitted with the offset for a Citroen BX, which is 20mm thick and have a 65mm mounting hole. There are 15 wheel bolts which will fit a Citroen BX, I can not find the 16th, but these are readily available from most motor factors.
  Golf MK6 GT TDI
Definitately go for a lower offset, the lower the offset the more the wheels stick out.
STD PH2 rims are ET45 I think :eek:
