Amp front door speakers
  Ph1 172 + Combo van
There is plugs from the inside of the car going to the door shut. You need to unplug them and drill holes to feed the cable through.
There is two guides in the guides section. So if you become a member you can see them both.
  Clio 200 LY/SV650S
I disconnected the two plugs between the doors and drilled through then fed the cable through the newly drilled holes. Gives a nice stock look with no visible wires.
  CLIO Iceberg 172
or you could be bold and trace the wires back to the head unit and cut and link them in from there to save drilling the door plugs
