amp needs two power cables
  GOLF GT TDI
i have got a precison power amp which needs two power cables and 2 ground cables should i use 2 ground cables on the power cap as well
Posts Will Be Grateful
thanks
-Stuart-
Djw John
Scotland - South
Dont bother with the power cap imo. But if you have to it needs a fused live from teh battery and then one to the amp and just the single earth.
  Polo + Micra
as above
i noticed a massive difference when i installed a yellow top and an extra 25mm2 earth
Djw John
Scotland - South
Basically a power cap will help with bass once- the first time. From then on it will take pwer away from the amp to recharge itself so will detract from sound quailty. Go for the same route that Dink has.
  GOLF GT TDI
Thanks alot for your help. I allready have a high performance battery will the stock alternator on my clio take the drain of a 1500rms amp
  Polo + Micra
nope lol
mine keeps going flat ans i think i've got the biggest alt ren do for the clio
  GOLF GT TDI
What rms are you running? Is there anyway i can stop by battery draining without spending loads?
  Polo + Micra
suppposed to be 1000wRMS but the voltage is set to be about 1200wRMS
and i think my alt outputs 98A at 100%.
I don't think it costs that much to get your alt re-wound to a higher output current
