I have a problem with 4 of the channels on my amp. they cause the speakers to make a high pitched wine. it is the front and back channels. the sub channels are still working. does anyone know how this was caused and if it can be fixed?
thanks
Have you run all of the cables together ??
If you have that will create interference, you should always run the cable to your amp away from the power lead etc.
I have ran the cables together yeh, but it was working without interference. is that what interference sounds like? i have never had any ICE in my car before so dont know?
its not interference. i have just moved all of the cables apart and it is still causing the same noise. does this mean there is a problem with the amp? if so then what problem?
thanks
