amp!!!?
  a black one
Looking at 4 channels so i can bridge to components, sub is 900w RMS, which amps should i be looking at, most of them are like 100 x 4 at 2 ohms i dont really understand it all, want it to be BOOMING, so need advice really,
dan
  Polo + Micra
900w RMS is a big ask from a class ab amp
imho i'd go for a 2 channel and a mono amp
what sub have you got?
  a black one
some awful in phase one probably isnt even 900 rms they do exagerate, i plugged it into my mates amp and was kicking hard, about the same as his 15'' kicker
  Polo + Micra
ahh right well you should be all right with that amp as long as you can wire the sub to show the amp 4 ohms
  Polo + Micra
it's the "resistance" the speaker shows the amp
too low a "resistance" and there is a chance you'll cook the amp
  a black one
so is 2 ohms more powerful than 4? im confused now, which power specs should i be looking at which are considered 'Decent'
  Polo + Micra
no in a word lol
you need to match them same as power ratings. bridging 2 channels can normally only run a 4 ohm sub or higher.
where as alot of mono amps will run 1 ohm subs but the higher the resistance the less power you get as the voltage doesn't change
although this doesnt apply to amps with a regulated power supplies i.e some jl audio amps;)
