Amping Front Components
Car  Clio DCi 65
How would i manage to amp the components in my door?
How do i get the wire from the door to my amp?
Also where would be a good place to put my amp if im going to be amping the front and back components?
its easyer said then done but with a bit off hard work you can wire them up going through the wiring sleeve, unplug the wiring connector block and you should have space to drill a hole in both parts without damaging any pins, its tricky but can be done, as for the amp/amps i have built a false floor, but you could also self tap it to you boot mat (not floor) and it should stay put.
Hope this helps and makes sense :S
bmh - when you want to get to the screws behind the silver bits, do they just pull off and click back on or something?
