anbyone wanna cool trick for their clio
Damn you Tomclio182 !!! you know everything and yes it is the diag mode.
but i have another which allows for a digital revometer in the trip screen. however you have to drive in diag mode. :D
  2.0 175dci rs meggy
just puts the needles through full test mode (travel) and also tells you if the instrument panel has a fault when the adac button is pressed again
  Mini Cooper S sport
Quote: Originally posted by Toypop on 02 October 2004
Whats the adac button and what exactly happens in this diag mode?
Yes - Id like to know too..
[Edited by Metallic Black on 02 October 2004 at 5:36pm]
Oh ok - I dont know where the button is though :oops:
the control stick for your wipers, there a button on the very end. hold that in and turn on the ignition (obviously only to full turn, you dont actually have to turn the engine on) then press the button to scroll through some meaningless info.
looks cool tho.
  Mini Cooper S sport
looks cool tho.
oooh thanks - will have a look :)
fooled everyone ages back with a closeup shot of my speedo at 122mph taken in the mode, had to be closeup to stop all the lights etc being in the frame. A little tip though is not to try it in a megane as resetting the ignition does not switch it out of diag mode! I had to drive round for ages with the dash going mental until it just stopped as i pulled into renault colindale!
Your RIGHT..!!
DONT try it in the megane.....SHEER PANIC
Tried it in my gf dads megane, and it wouldnt stop...(due to the car being keyless)...Even when you locked the car and looked in the window, the dials where still moving...
Turns out you have to move out of range of the car with the card key thing, as it doesnt actually turn the car fully off, untill out of range...
(due to the fact you dont need to press a button to unlock the car. You only need to walk up to it with the key in your pocket..)
IF THAT MAKES SENCE...!!!??
<--- ooohh err....69 posts....
[Edited by Kiev85 on 02 October 2004 at 8:09pm]
[Edited by Kiev85 on 02 October 2004 at 8:10pm]
I do hope everyone has tried out the speaker diagnostic thing on their factory fitted CD player....
(if youve not thrown it away yet)
Thats a pretty cool way of convincing people your clio is infact a spaceship. Do the speakers and dials at the same time to really compete the illusion.
Ta, Andy
<<<<<< 100 posts! FANTASTIC!!
does driving it in diagnostic mode do any damage or anything to the car in any way?
Think i will give it a go, when i get my car, NEXT WEEK!! nice!
Quote: Originally posted by Toypop on 04 October 2004
What about the digital rev counter trick?
Ive never heard of this he might be on about the fuel flow trick.
When your in diagnostics mods press the ADAC ie button on the and of the stalk and it cycles though the problems list and then shows a digital readout this is the fuel flow in liters from the pump.
Ok, so I tried this trick on my 172 this morning at 5am.
Erm, all it did was trigger my laserline alarm :(
Bloody imports ;)
  172, Tiguan
So i did the dashboard trick. What does 19L mean on the trip display?
It was all pretty cool though, lol!
Means there is 19 liters left in the tanks
My fuel flow trick wonly works with the engine running BTW.
You dont need to disconnect the battery...
Just lock the car and go out of range with the key card...
It should go off in about 5 minutes....
  2005 Audi A3 3.2 Quattro
I always thought it was the same as the current fuel consumption in regular mode.
You sure? Works in my mk1 172, which is why I thought it was current fuel consumption
Well its current fuel flow you could calculate the current MPG but youd need a constant spped for a few seconds to stop the effects on enrichment and thendivide speed by fuel flow (dont forget to translate the pump flow into gallons ie divide by 4.5461 first).
