use PDF's![]()
use PDF's![]()
PDFs wont open in indesign...inx is the only way and works a treat
Hi Res PDFs are bloody handy. I would rather let the client to get the printer to make text changes when they keep changing there mind on copy though![]()
The job is off to the printers - the best way to supply it is via PDF end of. No need pissing around packaging it as old files, making sure you got all the fonts and images aswell as possible problems opening the file at the other end.
PDF workflow people its the future![]()
Yep i know that PDF-X all the way!, just meant you cant open PDFs in Indesign as he asked what will open in CS2
The question was answered earlier on though - he also mentioned it was going to the printers which I recommended the best way to do that. You can also place PDF's in indesign - he didn't say it needed to be editable![]()
