Amos91
Honorary Member
After having some lowering springs fitted I thought I'd get the alignment checked out. Since I've had the car I have always had to hold the wheel slightly right to maintain a straight course. (Nothing has been identified as worn at MOT etc).
Anyway, it didn't actually feel bad before it went in but now its been done its even worse. Have to hold the wheel at about 10 past 12 and it drifts to the left when the wheel is released. Seems fine at low speeds but once you hit motorway speeds it is more prevalent.
Guy used a hunter machine to do it. He removed the locking pins, turned the wheel a full turn left then right and centred it with a holder. (I know it says Clio III at the top, but that shouldn't make a difference?)
Will probably take it elsewhere to get checked first but any suggestions on what else may be the cause? Tempted to swap the front wheels to see if it pulls to the right...
Alignment image which seems spot on to me!:
