Another bolt spacing thread?
  E36 Coupe & Mk4 Golf
I have done a search but could not find a specific answer.
So what is the bolt spacing for my 2003 1.2 16v clio dynamique?
Thanks.
Measure. Don't assume it's 58, it should be, but there are the odd ones that are different. Easier to take ten mins to take the wheel off than to order the wrong thing and have to send it back.
The two bolts where the strut bolts to the hub, just above the brake disc, measure the distance between them. Either top to top or middle to middle or bottom to bottom. You might be able to get in with the wheel on full lock, can't remember.
  Clio 172 Phase 2
I had to take the wheel off to get to mine. It should be 58mm for that model and year, but as said better to do a visual check.
Rob
Mike its exactly what I told you to measure, just do top of one bolt to the top of the other, if you're unsure I am 100% certain now after doing a bit of searching, so if you want a second opinion lemme' know.
