Ok so the tyres on my valver are 215/45/16 Will these tyres scrape at all on a Renault 5 GT? The 5 is lowered 60mm and I was thinking about the rear wheels catching on the arches?
I would guess that yes having been lowered 60mm they would definately scrape at the back!...unless any arch work has been done!
My mates 5GTT with my phase 2 16v rims was dropped at the back - but not nearly 60mm and there was about a 2mm gap between tyre and arch!!! And of course that was with 15"s!
I think you will find the 215s will rub quite badly. There is now a 195/40 R16 tyre available which should not cause too many problems. You will still have to trim the rear bumper back though.
Im hopefully picking a 5 up on saturday, but will have to swap the alloys from my clio 2 the 5. Theyre 215s. Can you run different tyres widths at back and front? ie 215 at front and 195 at the back?
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
