any 1 got this
  • Thread starter Thread starter v11ous
  • Start date Start date
V
v11ous
Hi has any one got a lowering guide for a mk2 172 my mates fitting some coilovers for me so i thought il help him out by showing him a guide cheers:rasp:
Fine for springs. For coils its slightly different. you'll need to remove the top mounts from the other strut and fire it on the coil. Set quite high...Roughly measure and fire them on. Back will prob require the platform to be bolted on. Again screw this up about 10mm...
What coils you got?
Then you must get them set up professionally. The camber and tracking will be a mile off.
i got gaz coil overs i wiil ge the tracking and camber doe after i lower it any guides on coilovers
