any1 got a code rader in blackpool area?
  Mk4 XR3i 90 - spec
sparks and sensors in kirkham will do it cheap enough. he's good too. guy called ryan.
  clio 182 cup
i had it plugged in by my mate at renault yesterday, its the abs serv and traction light and then my engine management light came on. this is because i have a milltek decat and its showing there is no catalyic in use and the other 3 are because i need a rear abs sensor
  Mk4 XR3i 90 - spec
fair enough.
simple fixes tbh. unbolt rear lambda sensor and tape it up out of the way to the underneath of the car, that should cure the engine management light. it's the rear most sensor which checks the cat is doin it's thing.
