bowen86
Before you say it, I've searched and although there are those with similar problems, none are like my issue, because I'm special.
I have NO brake lights and I have the ABS and SERV lights on the dash. I DO have rear lights and indicators.
Replaced brake light switch - still no brake lights. Pressing the switch with my thumb I noticed I had no brake lights but also no dash lights...
I pressed the brake pedal and instantly got the dash lights.
I've got RS tuner and it shows two faults with ABS but no codes as I don't have the ABS module.
How or why would the affect the brake lights?
Next thing to do is somehow get the ABS codes and then go from there. Will a generic code reader give me the code numbers?
Thanks.
Thanks.
