had this come on today, turned the engine off and it went off. any ideas?
A AKFM1 BG182FF May 27, 2010 #1 had this come on today, turned the engine off and it went off. any ideas?
badgerbite Clio 182ff May 27, 2010 #3 cheekymartin said: had this come on today, turned the engine off and it went off. any ideas? Click to expand... fuses, electrical failure, connectors and ECU etc. You need a fault code to be sure, as its a very general dash light warning.
Cro Meg'd r27 May 27, 2010 #5 Is it running bad? Go check the connection to the throttle body. Give it some wd40 and stick it back on
A AKFM1 BG182FF May 27, 2010 #6 its not running any different, so shall i wd40 the throttle body then. how is it taken off?
Cro Meg'd r27 May 27, 2010 #7 Just the connection not the body itself would throw that light up. Best get it plugged in anyway
Vicky. SG9 Forester STi May 27, 2010 #8 Renault charge £76 + vat to run a diagnostic test... Daylight robbery as usual. I used an OBD fault code reader from ktec which was £45. Its a good bit of kit!
