Anyone replace willy rear arches
Anyone on here do me a quote for replacement of drivers side rear quarter panel for a williams? What should i pay?
Ive got surface rust on the rear arch. Im down to shiney metal so i dont think its too bad, but wouldnt mind getting it replaced. Near side is fine. If i got the panel off another williams how much would it cost me to get it fitted (can i do that)?
When one of my mates had a full rear quarter replaced on his valver the cheapest quote was around £600, wasnt a bad job just had a few spots here and there where the spray job wasnt quite up to scratch..
Getting another panel of a clio could be more hard work than its worth mate
its possible to replace the arch alone not the whole rear quater using standard base model arch (you cant buy a 16v/williams arch, but it makes for a difficult job of concealing the weld along what is an alomost flat surface where as if you pay £400 for the rear quater from renault to welds are easy to hide and its will look perfect. But the parts is the killer.
  Titanium 182
rob let a pro bodyshop
remove all rust and treat it with rust stuff and then fibreglass and filler and it will be fine again
imo a whole new rear quarter cant be done on the cheap at all
it wont look right
letting a pro repait it if its not bad it will look ok
