172 SPORT PH2
So its being a problem for a while...
The problem being.. when im comming down from 5th, to 4th, it sort it sticks, then like a clunky type feeling when going into gear, some times its really smooth going into gears, some times its difficult and it does a clunky feel going into gear ..
It happens at any speed, but is happening most when im comming down from 50 mph, braking, and selecting 4th gear, to 3rd etc...
Its also a problem when going into 5th gear, it will like when i move it across to 5th ( > ) it like sticks, then it goes in ..
+ IS THIS A PROBLEM WITH THE CLUTCH
+ THE CLUTCH CABLE
+ THE GEARBOX
+ THE LINKAGE * I think its this *
Has anyone had this problem , ive also sprayed all the links that connect to the gearbox, all that mechanically move etc...
Any help will be soooo much appreciated!?
+ THE CLUTCH CABLE
+ THE GEARBOX
