auto lights and wipers
Err not sure if the extereme 4 had them if you do have them there should be a box unit in the center of the windscreen behind the rear view mirror.
Dip
  04 Clio 16V Dynamique
You'll also see the sensor through the outside of the windscreen.
  clio 182 black /gold
Start your engine and put your hand over the rear view from the outside of the car. Or just look for the sensor.
  Mondeo TXS Bardge.
to turn them on if you have them, tuen on the electrics, then wtist the headlight a fet times till it beeps, then turn off the ignition turn it back on and the headlight should be active, for the wiper you need to set them every time, you just move the stalk to the first click down and that them "armed".to test arm them then spit on your finger them wipe the sensor, and they should swipe.
on the out side of the windoe above the read view should be two things whihc look like unlit leds ina black square,if yuhave that you have autos if you dont you dont.
but i'm sure they only came on dynamiques and per a £400 option ont he extreme, but i could be wrong.
